BTD33
Hello all, I have a 16 2500 6.4 hemi with 162k miles. About 5 months ago my thermostat went out while idling loading cows and blew my radiator. While I was there I also noticed my water pump was starting to go so the truck got all new hoses, radiator, water pump, bottle cap, thermostat I also changed idler and belt and flushed coolant that was left and refilled with new coolant. Truck has been doing fine since, last week however it climbed to 240 so I cooled it down and noticed that my bottle was empty. I refilled with water since that’s what I had and the temp was fine and operating normally I am now losing between one and three bottles of water worth a day and cannot find where it’s coming out. I took it to the shop and he couldn’t find it either we have checked high and low for leaks or pinholes with pressurized the bottle we have to die in the system, we’ve checked the oil check compression hold the plug to make sure it wasn’t steam cleaned. I’ve done an exhaust gas test on the bottle. I’ve made sure that my heater core wasn’t leaking inside the cab. I’m not smelling antifreeze. There’s no fog on my window and both of my lines are hot. I cannot figure out where this antifreeze is going. It is nowhere in the engine compartment that we can find the only thing left that I can think of is it’s burning up on the manifold and it’s still a leak on the head gasket. Any ideas would be appreciated tonight. I’m going to pull the heater hose off of the water pump and just spin it over to make sure the pump is functioning properly aside from that. I’m at a loss. It does not overheat when driving and it does not overheat if it runs in the shade, it is only losing coolant when an idol in the sun, which makes no sense
