Coolant reservoir
Beasley907
Wasilla, AK
I have a 2015 ram 5.7. While doing a coolant flush I pulled the coolant reservoir to clean it. The hose goes about 3/4 of the way down the tank. Does it actually pull from here or is it just a expansion tank? It’s got the dipstick thing with minimum and max on it.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I believe that it is only an expansion tank
covering the radiator is what Ram wants to call a Sight Shield, instead of a dust cover. ( But it does shield a bunch of things from sight )
There is a radiator cap under there
Beasley907
Beasley907
Wasilla, AK
Yea I’m familiar with the radiator cap,that’s where I added the distilled water for the flush. Just curious if there’s anyway the system could pull from that tank. I mean they put a minimum and maximum coolant dipstick in it so to me that means there should be coolant in there. But I dunno seems silly to not have the hose at the bottom but there’s probably some smart engineering reason for it lol
crazykid1994
It’s only used for expansion. When hot it’ll flow into there. As it cools back down if there is space it’ll suck fluid back into the radiator. So yes fluid can go back out of it. It is not part of the pressurized system though so it does not have constant flow
GTyankee
3.0 ecodiesel
I just figured that when the radiator overheats just a bit, the excess goes into the reservoir, when the radiator cools off it draws that water back into the radiator
Beasley907
Beasley907
Wasilla, AK
Sweet just making sure I put coolant back in it for a reason. I was like why else would they put a min max mark on the coolant dipstick.
