cooper MT duck commander
Fergeson
Gloucester, VA
Anyone run these tires? just wanted to know how they ride, wear and how loud. any help would be great found a used set for my winter rims would like to get them soon
adubree86
Indianapolis, IN
2017 Ram 2500
Looks nearly identical to the Mastercraft MXT only with different sidebitters. I've run the Mastercrafts and they performed and wore good. May look into those as you can probably get them cheaper unless youre absolutely sold on that sidewall
EDIT: Just noticed you said you found a used set so I assume the price is right. If they are anything like the mastercrafts they should be a decent tire. The only thing I didn't care for on the mastercrafts I had was the weak sidewall.
F
Fergeson
Gloucester, VA
Ok thanks. Yes I found a used set for 200 and they all have 10/32 or better so I figured why not? I'm a little scared to put them on my 20x10 -24 rims because they look like they might throw some actual rocks and nothing like my terra grapplers will
adubree86
Indianapolis, IN
2017 Ram 2500
Think the MXTs started at 19/32 so those are over half worn. For $200 that's not bad but they will be starting to get loud. My mastercrafts got much louder once they hit 50%.
