Cooper S/T Maxx
ET381985
FedEx guy stopped by today! Can't wait to get these mounted!
N1ck
Regina Sk
What size did ya go with? Tread pattern looks nice :)
E
ET381985
I ordered 305/55/20. I should have them installed Monday morning!
E
ET381985
No level...air suspension and stock Limited wheels. I test fitted them before ordering. No rubbing but tires just barely "kiss" the sway bar at full lock
N1ck
Regina Sk
I will be putting 33x12.50x20's on stock sport wheels on Monday. Took it to one shop today and they refused to use the 1/4" spacers I have if it hits the uca. I'm hoping I don't need to use the spacer but I think 305 is about the max you can get away with.
E
ET381985
Every 305 will probably vary a little bit. These cleared the UCA just fine (by at least a 1/4"). If I use even a 1/8" spacer it probably wouldn't even touch the sway bar anymore.
RyanJM
Houston
2014 Express RC Black Edition
+1. I have had 305/60r20's on stock 20x9 chrome clads and had no UCA rub there was enough room but I rubbed the sway bar between 3/4 to full lock on turns. If you use a spacer spend the money and get a set of hubcentric spacers. I had some summit ones and got a wobble at speed like the tires weren't balance perfect.
E
ET381985
Pics!!!
Had them installed this morning...the truck now rides like a truck! Now I have 4 NEWish 275/60 SR-As to get rid of...
jlb
MT
CTD
The road noise on these tires is great IMO. I regularly get passed by guys on the highway, and can hear the drone of their tires. These are JUST louder than my OEM wranglers. They do walk when you try to corner more aggressively, and make some noise while the outer lugs ride hard through a corner, but overall I am a very satisfied. Traction is great in wet roads, icy, snow, offroad, etc. Dry pavement performance is underwhelming, but... what do you expect, they are very aggressive all terrains.
Clemzexp6969
Where did you order them from ?
Dbenson32
2009 Ram 1500 TRX
That wheel and tire combo looks fantastic!
Saltbreak
Maryland
4.7L V8
Awesome man. I just got them on my truck too. Very happy great in snow so far and very quiet! So far so good
Reticle918
