Could you guys do me a favor?
Hawaii_Built
Hawaii
ecodiesel
Give your front axles a good shake and post up how much play you have.
Do you have play when you twist it? Can you jiggle it in and out? does it sort of rattle when you give it a shake?
I noticed my front end was making a little noise going over speed bumps and driving on rough roads. To my surprise, these axles have a some play in them. I was under the impression that there should be zero movement.
Wondering how much is normal.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
IFS will have some play. As far as the noise my problem was the front wheel bearings. They went south after 87000 miles. 60,000 of them lifted.
WhiteExpress
Midland, TX
There should be very little 'play' unless you're a hell of a strong man!
There is a known issue with the axle retention clip being improperly sized / seated and it causing some grief.
Check out Boosted Motorsports YouTube channel, he has a quick video about it.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I have went through this and almost bought new cv shafts as I didn’t know there was play in them. You should be able to move in and out a little and it should have a little give if you lift up and down. There may be a little knocking sound if you lift up and down/in and out. Nothing overbearing though. I was surprised when I found out this is normal.
stimpy433
IOWA
Lyle Longboat
Bearings are tricky, you think they coming from One side, then you find out it’s the other side that’s gone! Plus sometimes, they don’t have any play in them and they still toast. I found this out as well. I use to be hard on the truck and went through 4 front wheel bearings (2 each side). Each time a different symptom. Go figure!
Hawaii_Built
Hawaii_Built
Hawaii
ecodiesel
Thanks for the responses. What Lyle describes sounds like what my axles are doing - little up and down and in and out movement.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Sway bar end links are usually a first check on front end noise hitting bumps.
Fatboy1989
