Cracked EVIC/Cluster lens
TMyers
USMC 84' - 92'
north wilkesboro, nc
Cummins 6.7
I bought my 2013 Ram 2500 6.7l early this year. I hardly have driven it at night, until last night. While driving, the dash light illuminated a crack that I had not seen.
It looks like the lens is replaceable but I'm have trouble finding the correct part number. Here's the specs:
DEF gauge lower left in Tachometer
Fuel gauge lower right in Speedo
3.5" EVIC
No other gauges
Anyone have a part number for the lens?
Thanks in advance!
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
3.5" EVIC
No other gauges
Thanks in advance!
I don't think you can get just the lens. Someone will correct me if I am wrong but I am almost 100% certain you have to buy a new cluster or find a not broken one from a junk yard and pull it.
1500ram12
5.9L Cummins
The shroud and lense can be separated from the cluster itself. But the lense is glued to the shroud and can't be replaced by itself. I believe a new shroud/lense can be bought for about $75.
TMyers
TMyers
USMC 84' - 92'
Cummins 6.7
I found this one (68205209AA) that I think is right but I can't find a picture. There are a few different ones so I want to be sure I'm ordering the correct one. Does anyone have access to Mopar part pictures?
geneseedennis
