Crank but no start???
viers87
Elkhart, IN
While driving today my 07 1500 5.7 shut off, no warning lights just died. Now it will not start back up, it cranks but wont fire. Any ideas or has anyone had this issue?
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
I had a problem like that one time,my used truck was in its best mechanical shape,But turned out to be a vapor lock in the fuel tank,I left the cap off for like 3 hours came back and she started up. Hope you get it going .good luck.OH also check the relay for the fuel pump might be stuck,Look it up on the index cover plate and gently tap it sometimes that will free it up if its stuck ,if it starts then I would replace the relay.
Karlsweg
SW Florida
Do you hear the fuel pump prime when you turn the key to “run” without turning the engine over? Either it’s fuel or spark related. How many mile on the engine?
Dodge 1500 4X4
Rochester, NY
See if you hear the fuel pump prime, it might be the fuel pump relay, I think you have a
TIPM where the relay is built into the circuit board there is a guy on here that makes a bypass harness to get you up and running. the site is www. VerticalVisions.com
Jason and Jennifer Bell 1-304-933-9391
P/S Totally Integrated Power Module (TIPM)
V
viers87
Elkhart, IN
It has 156,000 on it. I’m not getting any pressure to the fuel rails.
madtrucker2016
Yeah thats a way to check also ,But when driving it shut off so maybe relay crapped out ,the coil on them goes and will not hold the contacts in place. It,***** or miss on them but rare thing.
KAKA
