nekbroken
Hello,
I have a 2004 5.7 Hemi, was running fine, its an old plow truck and is not driven on the road. It had an exhaust leak, and melted / burned up the crank position sensor , knock sensor and their wires pretty bad.
I pulled the crank sensor and replaced, but I dont have a pigtail for it yet, i was trying to figure out what wires go where because there are three and I can almost make out the color of them way up higher. Looks like a pink with a stripe, a yellow with a stripe? and mabye a white?
could somebody tell me what order these wires need to be to what pins on the crank sensor? I have tried all combos but still the truck will not start. it looks like i do have proper fuel pressure and I have fire. I think its just compleatly out of timing because i dont have the sensor wires connected right.
part 2: the knock sensor was cooked too, i just cliped the wires and i really dont care if it runs rough or has bad gass milage, but will it run at all with no knock sensor?
Thank you,
ps.. please help soon before we get more snow and the driveway needs to be plowed again.
Thank you,
