Cree LED Fog Light Bulbs
nightrunner066
Wisconsin.
2014 Ram Sport
Hemi 8 Speed
Just thought I would share
I wanted to upgrade my fog lights But I didn't want to get HIDs because of the constant cycling from switching from low to high beam.
So i figured i would give these a try. They actually throw the light, unlike regular led fog light bulbs.
They have worked flawlessly for well over a month now. No bulb out warnings. etc.
They are 6000k in color ( I wish they were 5000k, but its the only option)
Here is a link.
High Power 9006 40W Cree-Xml2 LED Bulbs 2400Lm High Beam Kit White
nightrunner066
nightrunner066
Wisconsin.
2014 Ram Sport
Hemi 8 Speed
I don't have any at night. This is as close as i have to a night time shot. My headlights are 5000k in the pic. ( they have been changed since the picture to 6000k)
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Would love to see some night time from driver shots of the output.
BlownGP
Houston/Baton Rouge
Looks good. I want to try them someday.. They work well in projectors, but they won't be as bright as HIDS
InspectGWS
Houston, TX
2014 JEEP GC SRT8
I have used these (off Amazon.com) for about a month now and really like them...as fog lights...2000 lumens for each bulb...exponentially brighter than the stock halogen bulbs...
JDM ASTAR 4TH Generation Error Free 9006 HB4 Cree XM-L2 LED
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I wanted to throw LED 60w in the high beams of the projector headlights as I would like more light. I currently have HIDS in my projectors and fogs. ONLY reason is that I had a ffew kits laying around and a set of 9006 bulbs so just a pair of canbus adapters from retroshop and they were in for almost no cost.
Anyone have any ideas about the space constraints for the high beam bulbs? As u can see in the pic the OP uploaded the backs of the LED bulbs are huge.
Valth
Odessa, TX
I was also wondering about the size of the bulbs to. I've never really looked at my fogs from behind, do they fit easily/easily installed? Also I can't pull up the site in the original link, any other link? And are these the same as for the 12s? Looks great though.
BlownGP
Houston/Baton Rouge
How do they compare to oem projector bulbs?
Going by Lumens, they should be brighter. Stock Ram projectors bulbs are HIRs, which are better than normal halogens.
HID(High Intensity Discharge) vs. HIR(Halogen Infrared) | eBay
09-12 use a 9145 bulb.
I just found some 60W 3000LM each on ebay.
They should be hella bright
New 2014 60W 6000LM CREE LED Headlight 30W Bulbs H11 H9 H8 H7 H4 9003 9005 9006 | eBay
nightrunner066
nightrunner066
Wisconsin.
2014 Ram Sport
Hemi 8 Speed
i doubt they would fit inside the headlight housing for high beams.
Sam22
Did these throw any "bulb out" codes?
Sent from my iPad using Tapatalk HD
RyanJM
Houston
2014 Express RC Black Edition
I want a set for the my fogs. Did it sent off a code or any issue? I know with hid kits like my projector I used a canbus hid kit.
TheRudeDog
Here is a link.
I haven't looked under my truck yet to check out the fog lights. Is it an easy install or will there be cussing involved? Also, it appears you went with HIDs for your low beams?
ameer73
