Cummins Serial Number & turbo Speed Sensor
Kilgon
2025 Ram 1500 Crew Cab 4x4 6.4 Bed
SST 3.0L Hurricane
Hi,
Looking for some help on locating the engine serial number on my 2016 Ram 3500 with Cummins 6.7. I have had no luck finding it.
Also, does anyone know the correct part number for the turbo speed sensor? My truck is showing the 2580 code. I cleared it once but it has come back after about a week.
Thanks for the help.
Racer9
Erie PA
6.7 Cummins Engine Serial Number Location​
ByZaynPosted onJune 19, 2023Updated onJune 19, 2023
The serial number of the 6.7 Cummins Engine is typically located on a metal tag or sticker on the right-hand side of the engine block, just below the valve cover and above the fuel filter housing. The serial number consists of 12 characters that are split into three parts: a prefix (four digits), an engine family code (five digits) and a suffix (three digits). The first four numbers indicate what type of motor it is while last three numbers provide information about when and where it was manufactured.
K
Kilgon
SST 3.0L Hurricane
I searched everywhere and ended up going to the Dodge dealer. ESN is located on top of the valve cover at the rear under the cowl area. It is only 8 numbers. Have to hold the camera and slide it under the cowl to take a picture of it.
