Cup holder light
FlaglerMegacab4x4
So I ordered the ash tray/cup holder light thinking I had the right wire harness but I don't. :/ so what can I do now? I still want to use the factory cup holder light nothing aftermarket. Thanks
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
What all does it come with? If its a light with two wires tap it into an accessory wire to get power when you turn the truck on or power it to the headlight switch so it'll come on when you turn the headlights on.
FlaglerMegacab4x4
FlaglerMegacab4x4
It just has the light with no wires. Do I need to order the wires? This is what I have 4608669AB
Detox
Port Credit
Not sure what the unit looks like, but you will need wires.
You will need to wire the light to something that comes on with the headlights. you should be able to find one of the dash accessory wires to do this.
FlaglerMegacab4x4
FlaglerMegacab4x4
Yea but my issue is the light dosent come with any wires on it so idk how'd I'd even wire it.
HolyRamBatman
Deep in the Heart of Texas
When you say you have the light, do you mean just the bulb?
If it is just the bulb, you will need some kind of light socket.
Or is it a twist lock lamp that gets its power from a printed circuit board.
FlaglerMegacab4x4
FlaglerMegacab4x4
Here's what the light looks like
FlaglerMegacab4x4
FlaglerMegacab4x4
Sorry idk how to add multiple pics to one post
FlaglerMegacab4x4
FlaglerMegacab4x4
Yea I'm just not sure if I have the correct harness and if I don't then what do I do?
redram2007
Colorado Springs (Ft Carson)
Alright man this was very simple. It took me longer to remove the bezel than it did to mount and wire it up. Here goes, remove radio bezel and you will have a few plugs that are in the spare cutouts. The small black wire harness is what you need its on the far left. Next look inside of the center bezel area and you will see a cutout for the light. Insert the light, plug in the harness and your done. Its not very bright at all in the daytime so i assume it wont be a distraction at night. Heres the pics.
299927[/ATTACH]"]IMG_20130321_102811_031_zps41c4e55b.jpg
299929[/ATTACH]"]IMG_20130321_102836_810_zpse42a6246.jpg
299931[/ATTACH]"]IMG_20130321_102850_647_zpsf5f0be64.jpg
299933[/ATTACH]"]IMG_20130321_102917_856_zpsa7a5b06f.jpg
299935[/ATTACH]"]IMG_20130321_102933_718_zps7429a9a8.jpg
299937[/ATTACH]"]IMG_20130321_103011_567_zps3e7b7f3f.jpg
299939[/ATTACH]"]IMG_20130321_103021_710_zpsf2a4bc9c.jpg
299941[/ATTACH]"]IMG_20130321_103129_095_zps37bf7671.jpg
299943[/ATTACH]"]IMG_20130321_103553_454_zps2022421a.jpg
redram2007
Cool. Also after drivivng last night i noticed its not very bright at all. But it does the job which is seeing the cupholder at night without it being a distraction.
FlaglerMegacab4x4
FlaglerMegacab4x4
So I pulled the bezel today and of course I don't have the wire harness for the light so I guess ill have to find a scrapped gen 3 and cut it out and transplant it into mine.
redram2007
That sucks did you look in behind that panel bc it may have fallen back in there or not even pulled theough. I will be honest with you it may be easier and better if you did something led aftermarket unless you're set on that light bc its not very bright at all. I just did it bc you brought it up and it was only 10 bucks. There is a DIY on here for that using a couple leds and running them to power and ground. But of course a power source that has 12v when you turn your lights on only.
FlaglerMegacab4x4
FlaglerMegacab4x4
I appreciate your help bud. My dad has the light in his 07 so I know it's not the best however I'm trying to keep the truck as close to factory as possible in the interior. Idk it may sound dumb but that's just how I like my vehicles. But thanks again for all the help.
stevenmicheal
