CV Axle on 2020 1500 Laramie 5.7l
JDPATexas
2020 1500 4x4. CV axle, driver side, removed due to it no longer securely in place, causing excessive wobble. The splines on the diff are very worn, and cannot get a new cv on. No lift kit. This is how a bought it at the dealer. Can I now just drive in 2wd? It looks like the wheel is the same as the 4x2 model. Any thoughts? Thanks
Take both sides out and you'll be good to go.My 4X4 hasn't had the front diff / front driveshaft or CV's for 10 years.
J
JDPATexas
Thank you. I will check what it entails to remove the other side.
