Clarkdaddyyy
- Nov 18, 2014
- 4
- 0
- 1998
- 5.9L
hello everyone,
i am fairly new tho the blog so i will try to make it as short as possible with out too many dumb questions lol.
heres the low down..
I have a 98 dodge ram RWD 5.9L COMPLETELY STOCK
and my engine light came on
the problem i am having is a cylinder 5 misfire. sometimes it idles fine, but most of the time, and by most i means on almost every occasion, i catch it misfiring while idling. when i drive it, it seams to be a bit slugish and find it downshifting 2 gears low to find that power. it drives fine but feel like it is gettting that healthy beefy reponse take off like it used too. i took it to o'reillys and used their code reader.
since then this is what i have done to try to solve the problem
- changed oil and oil filter less than 300 miles ago
- refilled antifreeze
- changed out throttle pressure sensor
- check/refastened intake seal on the air filter
- bought seafoam (havent used it yet until i top off my tank again)
...still trying to do some more research before i try a compression test.
any help or ideas would be great!
thank you!!!
UPDATE:
Just found out i have the Death Flash
thank you!!!
UPDATE:
