Dang squeaky door hinge
grizzstang
Calgary, Alberta Canada
As mentioned a couple of times already. Fluid Film.
It creeps and is resistant to water.
At the first sign my drivers door is making a little noise I go ahead and shoot all 4 door hinges.
It lasts 4-6 months for me.
H
Haas
Wisconsin
I sprayed silicone on my door hinge and it's worked for a couple of months.
It thought of that, but I was told silicone was more of a lubricant for plastics, and not really for any metal products. Could be wrong though, I'll give that a try too.
H
Haas
Wisconsin
Fluid film seems to be the consensus. I'll see if I can find that somewhere.
bigdodge
This is exactly my experience. Works the longest
Sent from my Pixel 4 XL using Tapatalk
kad
Hudson Valley, NY
5.7L HEMI
If you've got an Advance Auto Parts nearby, they carry it. AutoZone does not. (the two I know from local).
-K
H
Haas
Wisconsin
-K
I've got both, so I'll check the advance auto parts first. Thanks!
Bluegill1
Ohio
This should be something I should be able to figure out, but no luck so far. My drivers side door develops a bad squeak when opening and closing it. I've tried spraying white lithium grease from an aerosol can on it. It's works for about 5-7 days, then the squeak comes back.
Had someone suggest oil first, then coat it with grease after oiling. Tried it, same result.
Is the hinge just shot? The door doesn't sag or anything, and nothing looks worn on the hinge. Only 28,000 miles in this rig, what else can I try?
Yup, it’s a known issue. Just got my 2014 back from dealer for some recalls and I see my entire hinge area is loaded with some kind of white grease from them. Unfortunately it still squeaks.
js12278
Central Illinois
When you get done using Fluid Film on your door hinges, go ahead and spray it anywhere you see rust. It will stop it in its tracks.
If you live in an area where they salt the roads, consider coating the underside of your vehicles with Fluid Film or Woolwax. Both are awesome products!
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
Our 2014 had same issue. Tried several products. Wd40, white lithium spray grease etc.. I happened to have a can of rv slide out silicone lubricant spray for our rv and decided to give it a try. Used it about a Two months ago and still no squeak.
duckman631
New Jersey
I didn't know it was a fairly spread issue. My 2014 does the same. WD-40 didn't do the trick. I'll try some of the tips shown above.
Sent from OnePlus 7 PRO using Tapatalk
Rv slide out silicone spray worked and still working after one spray on our 2014 drivers door. Going on two months and no squeak
KnurledNut
SemperFi
Sonova Beach
After many failed attempts, I tried garage door track lube. Works for 6 months.
H
Haas
Wisconsin
This is the answer. Just a little spray of your choice of lube on top of this part will do the trick for a couple months. No reason to coat every moving part in there.
That is the part, and others, that I have been spraying with white lithium grease, only to have it squeak within 10 days again.
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
I've tried just about every lubricant I can find and garage door lube seems to be the best.
All are great ideas that worked for a lot of people. I will also add, I had the same issue. I used WD-40 Dry Lube. It doesn’t attract dirt or dust and it keeps a dry film on the moving parts. It doesn’t get all over your clothes if you accidentally touch it with your clothes. It worked good for me.
Narg
Tulsa, OK
5.7 eTorque
Lithium is what is used by most OEM. It's what I use, and do so yearly.
chrisbh17
For me this lasts 10 days.
I think what is happening is the roller moves on the post, up or down, and thats when it starts squeaking. There seems to be a "sweet spot" where the roller rides the post without making any noise, regardless of what you use to lube it.
Opening and closing the door will cause the roller to shift slightly, Ive also noticed it happens 100% of the time if you happen to grab the door as you are getting out of the truck (for support, etc).
So I dont think its a lack of lubrication as much as it is *something* with the roller/post of the hinge. I believe the post is 7mm diameter where the roller sits. Was thinking of making some sort of plastic c-shaped spacer to put between the roller and the top of the post, to force the roller to sit in the "sweet spot".
Marshall
Sk, Canada
2014 sport
You have to get in the roller than, not just on the out side
