Dash core repair.
RamblerReb
Has anyone managed to re-attach broken bits of their dash core, by glassing or epoxy or plastic welding or whatever? How did you do it and did it work? I have to put back rather important bits and I'd like to know if it's feasible.
Any help appreciated, pictures or video doubly so.IMG_20190328_132406016[1].jpg IMG_20190328_132412639[1].jpg
Okiespaniel
Work, Shop, Computer
magnum, 5.9
I believe that your best bet is going to to fiberglass cloth and epoxy. Adhesives won't hold and when the joints do, the plastic snaps elsewhere.
At best a squirt of liquid model cement will hold things long enough for you to cover the area with matting.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Very interesting post ! Thanks Hope all goes well. I wonder what type of plastic the dash is ?
RamblerReb
RamblerReb
The crappy kind, my friend.
Seriously, I don't know if Dodge ever gave away the secret recipe. Maybe another member knows.
DodgeLady
Air Force
AZ
5.9 L
I know this is an old post- but I am in the process of rebuilding my gen 2 dash core. I’ve found JB plastic weld to be best. I had to order off amazon. It’s a two part clay-type roll that you cut a piece off of and work it like clay until it is a homogenous color. You can form parts from it or use it to re-enforce broken parts. Can rebuild fastener clip locations.
smokey1757
Well how’s it going on the dash rebuild? I am dealing with the same thing. Did you figure anything out. I am curious to know.
DodgeLady
Air Force
AZ
5.9 L
It’s going great! I’ve gotten a little bit sidetracked with some unknown whine issues...
I have pretty much gotten the ( what I call the underdash or lattice) rebuilt. I have installed my new LMC truck dash for a fit check. I’ll attach pics.
I have an innovative idea on how to install/attach my dash without removing it from the truck- too fragile. I’ll be posting here as that progresses.
These pics I have the old bezel snapped on. I need to move the right hand radio mount down about a quarter inch or so.
I’m very happy with how it’s turning out!
Reactions: Mop
DodgeLady
Air Force
AZ
5.9 L
This is a pic to show how bad things were when I started!! I had no top dash at all. No radio or hvac mounting.486e90f01b35b245ddbc44e36607f968.jpg20a54f130d8a6464677c65e2c2835303.jpg
DodgeLady
Air Force
AZ
5.9 L
See above. I’ll post a pic of the JB Plastic weld package later. I had to order on amazon. Stuff is amazing!
DodgeLady
Air Force
AZ
5.9 L
So how did you attach the old pieces together
I used JB Clear 2 part epoxy to glue plastic together. Then I used the JB plastic weld 2 part epoxy to reenforce where I could ( without interfering with the equipment mounting clear areas. It is tedious because you glue it in one place and it will break in a new place.
I’ve also glued pieces together by making a thin “roll” of the plastic weld and putting that along a broken edge and then fitting the edges together.
It takes patience! Some evenings I would have to force myself to do just one new “joint” so it could cure over night to be strong enough to continue.
DodgeLady
Air Force
AZ
5.9 L
Reactions: Mop
smokey1757
Well I hate that you had all that trouble but I’m glad to know that I’m not the only one. This thing has been about to drive me up a wall. I thank you for your advice and I will use it. Thanks Smokey
DodgeLady
Air Force
AZ
5.9 L
I had to order the 2 part clay plastic weld from Amazon. I could not find it in the usual locations- Home Depot, Lowe’s, auto zone.
713dodgeram
1998 and 2010
5.9 magnum, 6.7 cummins
I gave up trying to patch mine after rebuilding the ac / heater box. I am currently looking in junkyards to find the core and other parts that are good yet. It's better than buying one on e-bay for the quality and price , but I had seen where people have been doing dash swaps with other gen dodges.........
DodgeLady
Air Force
AZ
5.9 L
I wonder if Chrysler would send me a dimensioned drawing...I’d like to try 3-d printing parts of it.
