Dash Speaker Resistance Question
78Staff
US Navy Veteran
NE Florida
Bi-amp them to me is best, then you have control.
I used our KEY amp, then I can always add a bigger 4 channel amp, keep DSP and time alignment and use KEY as pre-amp.
So you run the 3.5's off the Key Amp, and the F/R door speakers off another amp?
In my case I have RD400 4 ch - Front Ch. running the Front Door/Dash combo (since this is how Ram wires them) and Rear Ch. running the rear doors. Then a dedicated sub amp.
I'm running the stock 8.4, and am getting ready to swap out my Metra DSP for a RF DSR1 later this week.
So in your example, I would split the Front Door/Front Dash combo, use the RD400 to run Fr/Rear doors, and then use the Key amp to run the dash speakers, if I am understanding correctly? Or any 2ch amp? That would resolve the ohm issue, and would give me control over the dash speakers separate from the front doors?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
No I used the KEY to the dash, and doors, bi-amp.
I mean you can run it like a normal 4 channel amp, just loose the DSP
Steven Skripka
Are there any real heat concerns with putting a 4ohm (25watt) resistor on your front speakers? I mean you're not going to melt the dash are you?
JustinRam1500
