Dazed an Confused
Phantom 309
2002 Dodge Ram 1500 4x4 4.7 engine. Truck ran great Saturday after noon drove 30 miles to town no issues. Parked truck for about half an hour, went to leave started truck it backfired!! Shut truck off went to restart it, it started but shot up to 6000rpms for idle.. replaced Throttle Position sensor, Air mixture sensor. Still wants to idle at 6000rpm... I'm dazed an confused of what's wrong with my truck.
OCDTech
Louisiana
Never heard of one that high, certainly possible, the first thing i would be looking at is the IAC, or idle air control valve. Seen one in a manual doing this, Idled at 1800, you would be going fast down the drive way on the brake.
https://www.rockauto.com/en/catalog...,fuel+&+air,idle+air+control+(iac)+valve,6072
Definately not saying go buy this right away, there was a test for the one i was working on, it failed so i replaced, all good.
Also thy can get dirty, you might can clean it.
May be a test online or in a manual. Just where i would start, it controls idle speed when you don't have your foot on the gas.
P
Phantom 309
I replaced the Throttle position sensor and the IAC. And the truck still does this. Do I need to reset the ECM or force the truck to relearn the new sensors. If so how?
OCDTech
Louisiana
I wouldnt think so. But did you do the battery disconnect and tie together for hour or so trick. Thats all i got
P
Phantom 309
Ok I'll disconnect the battery again, but what is tie together?
OCDTech
Louisiana
Disconnect take the positive and negative connect where they touch each other for hour or so. DO NOT LET THEM TOUCH THE BATTERY AT ALL WHEN DOING THIS ONLY EACH OTHER
P
Phantom 309
Thank you. I'll do that this week. Its -5 outside so not going to mess with the truck today. I'll let you know happens.
CVX20
Ont,Ca.
2019 Classic Express
Did you check to see if any of the vacuum lines blew off when it back fired?Any hissing noises when idling?This should set a code but it would definitely make it idle high.
P
Phantom 309
Cant check for anything vacuum related the truck starts and shoots straight to 6000rpm,
CVX20
Ont,Ca.
Just do a visual then.I suppose it could have blown out an intake gasket also.
SD4019
Wills Point, TX
Hemi 4.7
This maybe far fetched but check the cruise control cable on the TB. I once had one that would stick and hold the throttle open. Just a suggestion. Hope you get it figured out!
P
Phantom 309
Screenshot_20200131-222404_Chrome.jpg Need HELP figured out why my truck idles so high.
I'm going to guess that when it backfired it broke a glued in part off the back of the intake manifold.
I have searched on line but I cant find a replacement intake manifold.
Any one have any ideas??
In this picture it's the part where vacum attaches that blew off.
McBroom
Denison Tx
Hemi 6.4L
View attachment 193711 Need HELP figured out why my truck idles so high.
Can you get us some pics please
Were all better helpers with pics/vid's
Blue Mule
P
Phantom 309
Hope you can see the place I'm talking about where the vacuum attaches.
P
Phantom 309
I did find this on ebay but I'm unsure about a used REFURBISHED one. And before I spend $$ on the part I need to understand what happened so I dont put it on and it does the same thing again.
McBroom
Denison Tx
Hemi 6.4L
Look on rock auto and O'Reilly auto parts.
Blue Mule
P
Phantom 309
Already did both say there is no intake manifold for my truck. Item has been discontinued.
Cedar Plank
