Death wobble at 100+
cullen17
Fort Carson, Colorado
Just got my 100% stock truck up to 95+ for the first time and i've got a bad wobble once i hit 95ish i didn't push it any further to see if it would go away but once again my truck is 100% stock...
Lhemi
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
You've got either a bad tire or bad alignment.
Lhemi
Lhemi
OKC OK
Might check your end links as well. Post some pictures of your pan hard bar location.
TxGasPimp
Leander Tx
2005 and 2018
20180623_095150.jpg I have the same problem 2018 scsb ram 1500 2wd even at 65 if i hit a bump the ass end wobbles like a drunk fat ******* high heels called belltech and was told i need control arm relocating brakets,a bigger sway bar and pan hard bar great another 1200 in parts if i do the work myself
TxGasPimp
Leander Tx
2005 and 2018
So how many people with a lowered truck has the wobble? I was really wanting to do this soon but if it's going to cost $1500 dollars for it not to wobble I might just leave mine stock for a while. I thought the relocation bracket was to fix that issue.
TxGasPimp
Leander Tx
2005 and 2018
Mine does bad i have almost wrecked twice at over 100
Gary's Hemi
Walker, La
Yes you need atleast the Illicit no cut brackets. These trucks arent cheap or easy to lower the correct way
atom13
USA
Na
Na
So does anyone have a comprehensive list of items to do a 2" level rear drop correctly? I have a v6 2wd crew. My first ram. I came into this thinking it would be easier to drop than leaf springs. ***** now.
I have a rear shimmy when going over a particular large bump at 60. I installed the hellwig rear bar and it works great.
The funny thing is I bought this truck so I don't have to work on it. I also have all the parts except rwar bumper to do a dual exhaust but then read about back pressure problems and drone.
Quicksilver337
South FL
2016 Ram R/T
The adjustable panhard bar and bracket is one of the key components when lowering our trucks. Another key component is the Illicit Customs no-cut rear brackets. (Moe's has them on sale) They help put the rear end suspension geometry close to factory settings....pinion angle and center wheels to bed.
KAKA
