DeeZee Tailgate Assist issue
rendrag09
Is there any reason why the Dee Zee tailgate assist can't be installed on the passenger side? I just got my 2016 1500 today and it looks like someone drilled out the hole where the nutsert goes on the driver's side. IMG_7961.jpg
rendrag09
rendrag09
Someone moved this to 3rd gen, but this is a 4th gen..
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
It isn't designed too and will not work on the other side.
quietpeen
2021 TRX
Hellcat
Did you buy the truck used? Weird that it's drilled out
rendrag09
rendrag09
Yeah, It had a plastic plug in it that was superglued on, and when I pulled that out the final hole was huge.
Jwithing
STL
I would slather in a ton of JB weld and tape around it if you care about it looking pretty. Let it set, then drill the necessary size hole.
07MegaCabRam
Chandler, Arizona
6.7L CTD
Yes, there is NO difference in where you mount the shock. I believe the only reason it's on the drive side as there is no cut out for the tailgate to be removed. There is a little more slop on that side but will not hamper the performance. I had a friend that ordered 2 as he thought he needed two and installed both. They both work fine. Has had them in there for about 6 years now.
rendrag09
rendrag09
Ok I'll try this tomorrow and see if it fits
rendrag09
rendrag09
It does not work only on passenger side. It pulls the tailgate out of the socket like you're trying to take it off.
gville35
