Adding a tuner will take full advantage of the increased airflow a CAI and freer flowing exhaust will provide. Look at it this way - More Air In + More Air Out =- More Power. The internal combustion engine is just a big air pump.
I don't have the InTune as I adopted the Predator (prior generation tuner) on my 2007 a couple of years ago. The tunes, except for the CROM file, are basically the same between the two tuners.
The tuning options are pretty versatile and it gives me pretty much everything I need. It would be nice for some transmission shift at WOT options. The tuner must add some line pressure as the shifts are crisp and positive, with no slippage, regardless of the throttle pressure. At WOT, it won't bang hard but it does hold gears up to just below the stock redline. Again, the shifts are firmer. I'd like to tune the shift points at WOT a bit. But, it does kick down sooner when I step on it while driving on the freeway or around town.
I run a 91 octane tune in my truck with an AFE cold air intake and Magnaflow single in/dual out muffler. With that combination in place, I did a baseline run on a dyno then added the tool and did another run. While on the face of it, the gains are not all that impressive until you start looking at the HP and torque numbers at the beginning of both runs.
The torque rating increases dramatically and comes on much lower in the RPM band. It also sustains a higher rating across the entire dyno run. Torque moves the truck so this really makes the truck feel responsive with no lag between the time you depress the pedal and the truck moving.
HP ratings also increase at a lower RPM and are sustained at a higher level out to the end of the run. It appears the tester backed out of the truck vs. taking it all the way to redline but that's OK. The chart does demonstrate an increase across the board all the way to the end of the run.
On the chart below, the blue dotted and solid lines are stock torque and HP, respectively, at the rear wheels. The green dotted and solid lines are torque and HP, respectively, at the rear wheels with the tuner installed. The gaps tell the story.
Now, I don't want to get too technical on ya but I gotta touch upon Air Fuel Ratio as it's an important component of engine performance.
The stock program on the HEMI engines runs a bit lean, around 14.1 static (idle) and it may drop to 13.8 or so under WOT. I say lean as I know that a richer mixture (below 13) makes more HP and reduces knock retard (which is a pretty aggressive setting in the HEMI) on these engines from previous tuner installs and testing.
There's a couple of reasons for the stock settings but the biggest reason is fuel economy. All manufacturers have a Corporate Average Fuel Economy (CAFE) rating they are held to by the government. Any model, like my SRT8, that falls below the CAFE gets hit with the "gas guzzler" tax, raising the cost of that model and making it less competitive in the market. The other theory is that a lean mix will burn better, leave less deposits and increase engine life. In reality it limits vehicle power as a lean condition can be a precursor to knock and we have a very aggressive knock retard setting in the PCM. I've gone as far as swapping out knock sensors on other small block engines just to get some more room to play with on fuel mixture but that's another story for the Bowtie boys to share.
Well, I don't buy that theory and I didn't buy the HEMI powered MegaCan to get great mileage. If I wanted mileage, I woulda bought a Prius. What I wanted, though, was a truck that eats Prius'.
Prior to the tuner install, we did a run on the dyno and measured the HP / Torque ^^^^ and also the A/F. The stock run saw no improvement in the A/F, with it sitting at 14.1 - 14.2 at WOT all the way out to around 4300 where it dropped off a cliff and got really rich. So, across 75% of the run it was lean. We didn't log knock retard but I suspect it was pretty close to the limit.
After the tuner install, the change was dramatic. A/F started dropping into the mid 13 A/F range at around 2700 RPM (note that the HP & torque curve improvement starting around then as well - direct correlation) and as the engine demanded more fuel, the tune delivered more fuel, with the A/F dropping to around 12.5 A/F. I've been involved in tuning other 5.7L HEMI engines on the dyno and most seem to perform at their best right in this area. Here's the chart. The blue line is the stock run, the green line is the run with the tuner installed:
The bottom line is that I have more HP, more torque, the truck is much more responsive to throttle inputs, it shifts better and I did see a mileage increase around town (just a bit under 2 MPG) and better highway mileage (almost a 4 MPG increase) with the installation of the tuner.
I'm glad I purchased the tuner and I'm very happy with how it moves that big MegaCan.
