Did anyone add a spacer to their Fox coil-overs?
Ram7081
Hurricane 3.0
Still doing my home work on the coil overs. I like my Fox rears and the front are an options now. But at 2" of lift makes me rethink. That's until I was shown the 1/2" spacer. Would they really be bad/firmer if added? I see most are same extended link like Fox and King, etc. But some are 2" while others are 2.5" lift. Any input?
Thanks
https://wulfsuspensions.com/collect...-1500-4wd-1-2-leveling-lift-kit-strut-spacers
misfit77
Interested. I did rancho quick lifts. Recently added a winch. I was rhinking of doing additional 1/2 spacers.
Sent from my moto g power using Tapatalk
Ram7081
Ram7081
Hurricane 3.0
I'm thinking since most are the same extended link but offer different lift sizes (2" and 2.5") it shouldn't matter? I am hoping someone tried it with feedback.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I’ve got a set of those same Wulfs in my garage in the event I need the when I swap OEM springs to Eibach springs on my 5100s.
I guessing it will all depend on CV angles that may determine if I run em or just deal with “as close as possible” as I can get
Panamaximus
USA
I can't find the 1/2" rear coil spacers. Is there a better link?
Panamaximus
USA
What brand? What material? Top or bottom? Price? Shipping?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Thanks
Have you looked into the bilstein 6112's they pair with the fox 2.0 rears well
Right now from your signature line it looks like you are running the RC N3 coilovers? What is your end goal? to keep a level truck with a better ride? lift it higher later? I would highly advise against stacking a spacer on top of a coil over. The main reason is a coil over does not have an OEM top hat that most spacers use. My Fox 2.5 coilovers do not have studs that stick out the top for example. It sounds like you would be better off looking at King or Icon or something you can order a custom length application for.
ChloeBrooks
