Diff fluid? Torque specs? Can’t find it?
2004DRDye
Farmington NM
Cummins 5.9L
been trying the search…not coming up. Wanna change my front and rear diff fluids and can’t find amount needed for each… and can’t ding torque specs to re tighten. I’m having issues finding this on here. Probably right in front of me‍♂️
HemiLonestar
Navy Badge Coast Guard
MD
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
I have never used a torque wrench on diff covers on my old 06, I used good & tight an for the 15 years I owned it never had it seep or leak...
2004DRDye
Farmington NM
Cummins 5.9L
Found 2.45 liters front and rear diff. I have the 2004 SLT 2500 4 wheel drive. Will this need a limited slip differential additive in it? TIA
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Depends who you ask. I was reading a thread on this site yesterday that said all modern gear oils include the friction modifier so you don't need to add it separately. I'd need to do more research.
I had the tranny shop do mine on Monday while they were doing the transmission and I didn't ask what they put in so I can't tell you what they used.
Ron Boggio
Sumerduck, VA
5.7l
Just did mine last Friday:
75w90 (Royal Purple states LSD additive on the front of the bottle, as well others do to)
2.4 qts front axle (approx)
2.65 quarts (rear Ram 2500/3500 10.5" axle)
3.81 quarts (rear Ram 2500/3500 11.5" axle)
32ft fbs torque
zogg
Southern Illinois
2018 Ram Express Quad Cab
I did both of my differentials last week. I used Royal Purple 75/90 for both. Then I changed the transfer case fluid with mopar stuff at $30/quart. Grrrr
Anyway I just tightened all fill and drain plugs hand tight plus 1/4 turn. I’ve always don’t it that way and never had a leak
