Difference between 09-11 and 12+ trucks
GunnerJ
US
I keep hearing that the 12+ trucks are somehow different than the 11- trucks body wise somehow, but i just cant seem to find what it actually different. I have an 11 cummins and my landlord has a 16, and everything looks the same, i cant even tell a difference with the grill. Can someone elaborate please?
quietpeen
2021 TRX
Hellcat
2013 is where they body style (mid gen refresh) happened. However in later model 2012's a few little changes were incorporated(nothing visual).
Basically 2012's are the same as 2009-2011.
huntergreen
The end of 2013 production is when they added the 8 speed zf trans. That was the biggest change I am aware of.
In 2011, the rear diff was changed to zf axle. Other than those and some small changes, there isn't much difference.
quietpeen
2021 TRX
Hellcat
with the 13 refresh that started the 8.4 uconnect and a lot of electrical changes
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
The only thing I miss on my 2011 or wish is that eight speed tranny with my 3:92 Axle
Man those eight speeds are sweet , and then you combine the 3:92 Axle , fun fun fun
GunnerJ
GunnerJ
US
I know about the difference in the interior, electronics, drivetrain, and such, im wondering what the difference in the bodies are, i should have clarified that. Like when i look at grills on amazon they specify 09-11 or 12, and then 13-up
I cant visually identify any difference between my 11 and my landlords 16
quietpeen
2021 TRX
Hellcat
The most noticeable difference in the grill is the bottom corners angle up or the technical term have a chamfer. The grill itself is actually taller also
2011 grill
2016 grill
quietpeen
2021 TRX
Hellcat
Next noticeable difference is horizontal fogs on 2009 through 2012 and vertical on 2013 through 2018(not grill related though)
2013 is also when they started thermal management.The outdoor temp sensor was moved from behind the grill to the drivers side mirror and it was tied into the 6 speed transmissions shift programming.
kkreit01
Olathe, KS
I know the cosmetic and electrical differences, because I had a '12, and now '18. However, what changed as far as intakes go? I see some intakes say for '09-'12 only. I know there was a slight increase in HP/TQ as well...
GunnerJ
GunnerJ
US
Did the body changes also effect the HD trucks? The grills on the 16 and my 11 seem to be identical, even in the bottom corners
Orca
