Differences?
Silver
Lumberton, TX
What is the difference in the parts between a drop kit for a crew cab, and a drop kit for a quad cab??
retiredfireman
Maryland
I would call to be sure. If the seller/company isn't sure check other retail places.
It might not be anything., but a few calls to be sure will save you headaches.
reefguy89
laurel de
what kit are you looking at? what do you have qaud or crew? If i had to guess i would say a length differance since they is differant kits for each.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
There shouldnt be any difference between the crew/quad cab kits. The difference is between the quad/crew and the regular cab kits.
The spring rates are what is different. 4 door is heavier, so using those springs on a RC will not give you as much drop up front as the RC springs. Rear springs should be the same.
If going with the McGaughy's deluxe kit, it is the same for all rams because the front springs are not changed, only the spindles.
S
Silver
Lumberton, TX
Ok, thanks Moe
S
Silver
Lumberton, TX
I'm in the Beaumont area, do u have a shop or all online?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
We are strinctly online, but there are some great shops not far from you. Look up BNC Offroad. They are closer to Pasadena, but their work is worth the drive.
