Dim Dash Lights
Pedal2metal
Myrtle Beach
I replaced all 8 gauge cluster bulbs and still have very dim cluster. I’m getting 12 volts through the fuse when light switch is turned to bright. I thought maybe it’s a bad ground but the gauges work and it appears they share the same ground. The high beam indicator is bright as well.
86 D100
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
did you check the 'rheostat' type switch that dims the dash lights? maybe it went bad?
joshhhh
