Dire need of help
Ganarful
Meade kansas
5.2 v8 magnun
My sons 1996 dodge ram 1500 wont crank only will start if I bypass starter relay, tried different relay out of a different Vehicle I know starts and no go. Is the ignition switch my last option for replacement? The I.O.D. fuse was blown when I started checking the starting issue. I've replaced starter, battery, cleaned cables, replaced cable ends so far. Started by jumping the relay and went a mile across town. When stopped to shut off vehicle motor kept spinning, than smoking. Smoke came from the starter area and will not start when I jump relay contacts now. Please any help on this is great thank you.
Shadow_Death
Killeen, Tx
When you say it kept spinning do you mean like if you were trying to crank it with the starter?
G
Ganarful
Meade kansas
5.2 v8 magnun
It didn't sound like it was cranking but acted like it. I'm gonna look for burnt wires on ignition switch and behind fuse boxes just in case there is a short.
rrb6699
Orlando FL
may have burnt up the starter. or wires to it.
