DIY: 2013-2014 OEM Steering Wheel Audio Control Install
HDJeep
Newbie here. Just finished installing the audio controls and the new front switch with the V/R and "phone" buttons. Just wanted to thank you for a wonderful write up with great pics. It went just as easy as you say. Just have to take your time and not be in a hurry.
Next is footwell and underhood lights.
This forum rocks!!!
Once again, Thanks
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
68Malibu383
Thanks for the post. A couple of things... I put locktite back on the steering wheel bolt (factory had some so I reapplied), the "spring" clocking can easily be checked/fixed by lining up the arrows at the approximate 7 oclock position, there is a left and right radio button but if you put them in the wrong hole, it is easy to switch out.
Excellent upgrade and thanks for the posts.
R.L.K.
Bristol , Tn.
How in the hell are you guys getting a puller on this wheel?
LOL I just ****** mine a couple times and then while holding constant pressure pulling on one side I smacked the other side a couple times and off it came .
Good luck !
kg93
AZ
The one I rented from pep boys worked just fine
Sent from my LG-H900 using Tapatalk
jcollins28
Rancho Cucamonga, CA
Good luck !
I can't get an even pull on the wheel with my 3 finger puller because of the connectors at the top of the wheel. Guess I need to eat my Wheaties and try yanking on it.
00R/T
CT
The second time I pulled mine off, I just yanked it. I'm not sure if I could have done it the first time or not, but I used the same method as when I pulled one off a column I bought (no way to yank with the column outside a truck).
I couldn't believe these wheels aren't threaded for steering wheel pullers and none of my 3 jaws would fit. So, I ended up using my steering wheel puller but instead of threading into the wheel I ran the bolts through the holes in it and put nuts and washers on the backside. It worked like a charm.
jcollins28
All done!
Mpgrimm2
SC
5.7L
Good luck !
Uh, what are we talking about?
Sent from my SM-G930P using Tapatalk
stretch78681
Texas Hill Country
2018 BIGHORN
5.7 squirrel cage
Wheel removal?
What The Flipp?, I can't get that far! Spent 2 hours working on the air bag. Beautiful day, all the time I needed, couldn't get one clip off! Moved to emptying beer cans.
R.L.K.
Bristol , Tn.
To see better use an inspection mirror or if you have a smart phone ,prop it up on the cluster and turn on the camera and flip camera to the front as I did , this worked like a charm for me .
To dislodge the 3ea tabs I used a snap on cotter pin removal tool , this tool works great .
Another tip is apply slight pressure pulling the airbag towards you while removing the clips , if you don't the clip will snap back into place and your starting over .
I also recomend jacking the front of the truck Untill it's light on the tires to aid in turning the wheel to get to all the clips .
Hope this helps !
MaizeNBlue
Using your phones camera as a mirror works great! Couldn't of done it without it.
