Do ALL 3rd brake lights leak?
Cmsharp
Rogers, AR
Just looking for feedback from other members, do I need to add a rubber gasket or silicon caulk to my 3rd brake light if its not leaking? I wasnt sure if maybe Ram fixed the problem yet? I have a 2016 model. Thanks
quietpeen
2021 TRX
Hellcat
No not all leak. My 05 and 11 never leaked. I have not had my 16 long enough to say it won't leak
TerraNewf
NL, Canada
My 2015 didn't leak the 2 years I owned it, 2017 is too new to tell. Knock on wood it's ok
Bobbo
Los Angeles, CA
My 2016 didn't leak with the factory light and still doesn't leak with the Spyder auto light.
Dbush36
Fort Wayne IN
I have a 13 express with factory light. No leaks yet. I have changed the bulbs so I would think if it was going to leak it would have by now.
mpress2570
If you look at the seals on the newer models they are a little more heavy duty than the old foam seals
DRkNESS
South Jersey
My 2011 has never leaked, but I have a new one in box just in case.
DRKNESS falls
EagleChief
Oklahoma
2014 Big Horn
I have a 2014 and never had an issue for 3 yrs. I changed bulbs recently and for peace of mind, went ahead and pulled the foam off and replaced with rubber weatherstrip.
mpress2570
Yeah my 17 already has a rubber gasket so I'm hoping I'll never have this issue
Cmsharp
Cmsharp
Rogers, AR
Guess i need to quit being lazy and pull the light off to check the gasket. Kindof silly that these company's cant fix a simple problem though! Thanks for the comments
2013 black Crew Cab Express
2 leaks
My 013 leaked twice on me. But is was under warranty.
I had a 02 Dodge Dakota for 11 years it never leaked.
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
My 2013 has the original seal and has never leaked.
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Oh I'll chime in too....my 2011 I bought used had the leak and water-stained headliner in the back. Some black RTV sealant took care of the leak and I cleaned the water stains easily with upholstery cleaner like they were never there. No problems ever since.
