Dodge Turbo Diesel Diagnostic Trouble Codes
Geno's Garage
*******, GA
Cummins Diesel
If you work on your own Dodge Cummins Turbo Diesel and we suspect that many (most?) of you here on this forum do so, you've probably run across a Diagnostic Trouble Code (DCT). The TDR put together an article on these codes and you might want to print it out and keep it somewhere around your toolbox.
It is from our Technical Information and is in PDF format. You can read it here.
