In laymans terms when it comes to ICE engines, HP is torque X rpm divided by 5252,lets employ the "Kiss principle" here,hopefully you know what that means.Some guys might be baffled with BS,but i'm well past that,lol.This is where you are going off the rails.
Torque is only a force. HP is force x distance/time.
Put 100# on the end of a 1 foot long bar that is perpendicular to the ground and anchored so that the fixed end cannot move. Like on a lug nut that you've already set to 100 #/ft. The torque is there for eternity, even though the tire is not moving.
Now, if that lug nut is attached to a wheel/tire that is in contact with the ground, and there is little enough resistance that the wheel will start to turn, you then have HP. If you maintain force perpendicular to the bar, HP is the result and will vary based on how fast the wheel turns and how much force is applied.
An open diff (apart from extremely small, generally unmeasurable differences due to manufacturing tolerances) will ALWAYS apply equal torque to both wheels. It's physics 101. Ok, maybe 102.
You do have the same amount of torque applied. Unfortunately, the tire with the least traction limits the amount of torque that can be applied....according to your theory of applied torque to the tires,you should have the same amount of usable torque at both tires,and drive right out of the ditch/snowbank/mudpit etc.
No one "needs" an LSD. For decades 99+% of vehicles driven were 2WD cars with open diffs. FWIW I have an LSD in my truck and would never buy one without it unless it were not possible....your idea you don't need a limited slip diff,in a snowbank![]()
My response was to the claim that without LSD you only have a 2WD truck when you paid for a 4WD one.
You can lead a horse to water but you can't make it drink.
You can be as dismissive as you like but the problem is, you are talking to guys who actually use our 4x4s in really rugged locations. Deep mud, snow, loose rock, steep grades etc. However you cut it and whatever the theory, lsd in the rear and a locker in the front will take you WAY WAY more places than open diffs in really tough country. Brake limiting and traction control are actually handi caps in most really bad terrain. I know this doesn't apply to 70% of 4x4 users but for some of us, LSD and/or lockers are not nice to have, they are need to have.You can lead a horse to water but you can't make it drink.
Peace, out.
Here's a test for you to do with a pegleg truck,lol. Find a dyno shop with an in ground dyno,ask them if you can back the drivers side tire onto the roller,and keep the pass side of the truck off the dyno,then jack the pass side rear tire off the ground,and chain the hell out of the truck to the ground so it won't fall off the jack,then fire the truck up and put it in gear and give us the dyno reading off the drivers side tire.Remember dyno's only read torque,so using your theory we should get a dyno number off the drivers side wheel showing applied torque. I'll wait for your hypothesisYou do have the same amount of torque applied. Unfortunately, the tire with the least traction limits the amount of torque that can be applied.
I think you nailed itI think he's just trolling at this point.![]()
(By the way, not trolling)Here's a test for you to do with a pegleg truck,lol. Find a dyno shop with an in ground dyno,ask them if you can back the drivers side tire onto the roller,and keep the pass side of the truck off the dyno,then jack the pass side rear tire off the ground,and chain the hell out of the truck to the ground so it won't fall off the jack,then fire the truck up and put it in gear and give us the dyno reading off the drivers side tire.Remember dyno's only read torque,so using your theory we should get a dyno number off the drivers side wheel showing applied torque. I'll wait for your hypothesis![]()
Give it up Dude,as all the theories in the world aren't getting you unstuck. Nobody really cares about "applied" torque when they're stuck,they care about usable torque,and when one wheel is spinning on ice,and the other axle or spider gear isn't applying any usable torque to the wheel with traction,you're still stuck.(By the way, not trolling)
Yes, the tire on the dyno is showing the applied torque. If you could measure the torque on the tire not on the dyno it would be the same.
I don't know how many times I've said this but apparently it's not sinking in. Guess I'm better at comprehending than teaching.
I know "it's the internet" and you can"t "believe anything on the internet" but I have yet to find and article from a seemingly reliable source that says anything other than "an open differential splits torque evenly between both wheels".
As I've also said (perhaps in different words), that does NOT mean that it applies the most torque available. And again I say that does not mean I recommend against getting an LSD - I would not order a truck without one (yeah, said that too). Yes, an LSD or Locker will get you out ot places an open differential will not. ALL I'M SAYING IS THAT AN OPEN DIFFERENTIAL APPLIES TORQUE EVENLY TO BOTH WHEELS, which a torque-load of peeps on here seem to have no idea what that means.
Seriously - when I said before that it's physics 101 I meant it. Maybe the forum should require an entrance exam before posting is allowed in technical forums.
It explains how the spider gears works pretty decently though. I remember that video from my shop class in high school way back in the 70's,lolI always loved this ancient video from GM describing how open diffs work, maybe it helps:
Around The Corner - How Differential Steering Works (1937)
How the automobile differential allows a vehicle to turn a corner while keeping the wheels from skidding.Differential steering From Wikipedia, the free encyc...youtu.be
Just what possessed you to think an engineering theory that has no real benefits in the real world,would apply to the OP's question.About all i can come up with,you were thinking you were smarter then anybody else on this thread.Apparently I'm a bad teacher. I really think we are all saying the same thing, but there is one little point that is being missed.
What I'm saying is that an open diff applies equal torque to each wheel - that DOES NOT mean that it's the best way to get unstuck (or keep from getting stuck in the first place). In fact, it's the worst.
If I have one tire on slick ice and one on dry pavement I want the tire on the pavement to have 10-100-1000 times more torque applied to it. This is not possible with an open diff.
That is all I have said from day 1.
It's not a theory, it's a fact.Just what possessed you to think an engineering theory that has no real benefits in the real world,would apply to the OP's question.About all i can come up with,you were thinking you were smarter then anybody else on this thread.
All you've accomplished is a few of us really question your common sense
I guess you can think that,if it makes you sleep better at nightIt's not a theory, it's a fact.
A fact that may cause some to stick with the stock open differential, others to go with the LSD and still others with the locker.
As for how "smart" I am, I try to always surround myself with and hire people smarter than me, with the goal of me being the dumbest person in the room. Unfortunately, I do not have the same option in an online forum.
