Does anyone know what the accessory purpose of this area is supposed to be?
gypsy400
I jam my ownership and insurance card in there
Sent from my SM-G903W using Tapatalk
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
it's TRUE purpose...
Um... Where did you get the switch panel?? Is that Mopar factory? Self-fabbed? Available somewhere I haven't found? That is what I am wanting to do with my left-hand "pocket" but just haven't gotten around to fabricating something!
sbarron
Wasilla, Alaska
It's a 2 switch holder from OTTRATTW held in simply by friction. The black "triangle" on top is just a piece of back plastic cut from a notebook cover and glued to the back of the switch cover. I can take this out and other than a hole drilled way in the back of the cubby for wiring, you'd never know it was there.
Gregory ONeal
Pierre Part, La
Hemi 5.7 liter
I have a 2015 Longhorn and I use that spot to store my Ray-Ban's. I find if I store them
above the dash they get so hot in the sun they will burn you when you put them on. Miss
my overhead storage like I had on my 2000 Ram.
Porkbutt
I keep my garage door opener in it. It fits perfectly.
iland99
MN
2017 Crew Cab Express 4x4
I keep an extra magazine for my carry gun on the driver side cubby. Bluetooth OBDII code reader on the passenger side.
Dusty
Rochester, New York
Be advised that in the back of that little cubby on versions with it on the right side there is a screw for attaching the bezel to the instrument panel.
Regards,
Dusty
2019 Ram 1500 Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, factory dual exhaust, 18” wheels. Now at: 004204 miles.
MarshRam
2014 SLT 4x4, 2012 ST
That's where I put those real sticky boogers that I can't seem to fling off my finger. Wipe off real easy on that rubber mat in there and it's easy to pull out and clean off.
:happy175:
BBJ0227
My space is open over my inverter. '16 Ram Longhorn
BBJ0227
My question is what is that slot on the top of the dash above radio that says RAM?
Donutsahoy
6.4L Hemi
I park in a parking garage so it's a perfect place for my sunglasses. I've also seen people put toothpicks there but mostly I see sunglasses.
kad
Hudson Valley, NY
5.7L HEMI
There's a screw Under it if you want pull the radio out
Only on some trucks, I believe it's the ones with the full center console. My '14 CC, with the jump seat setup, does not have a screw in there.
-K
TXCOMT
I put nickels in all those cubbies every time someone asks what all those cubbies are for...I'll be retiring soon!
Sorry, OP, couldn't resist!
TXCOMT
