rroche1982
Has anyone wrapped the inserts in the door in a different material? Looking at doing something custom inside
That looks awesome!!!!! Thanks for the responseI did. It’s simple really. Door panels pop off then you can access the panels from the back. Grind the welded plastic tabs off that hold the insert in place. Rewrap and then when you put it all back together I used small self tapping screws to hold the insert in place by screwing them into the existing plastic tab areas.
