Door lock knob removal
jordang
Canada
If I remove the door lock knob by the window, will it impact the trucks ability to lock and unlock normally?
My concern is the locking mechanism will get stuck in the hole and not be able to pop up as the knob guides it up.
Anyone done this before?
J
jordang
Canada
Anti theft. Have you done it or know anyone who has? If I’m able to pop it back up even if it gets stuck it might be worth a shot
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Can you pull yours up with your fingers when it's in the locked position? Is your 2021 a Classic or a true 5th gen? I ask because in every 5th gen we've owned (4 total), there's no way to pull the lock knob up because it sits flush with the door panel when it's locked. Because of that I don't see how it's vulnerable to someone using the knob to unlock door to gain entry into the cab.
I can see someone removing it because of the reported "lock bites" some people have complained about. It hasn't happened to me but supposedly it's a thing.
Dean2
Near Edmonton
On the 2021 2500 and 3500 it is not flush when locked, so that may be the OPs basis for the question.
There is a device, if fact at least 2 devices
Hell the are several ways to unlock Ram doors with out a key or FOB
You can drive a air wedge in between the door & "B" pillar & you have several options
BIG EASY
whatever you do, do not bend the Lock Knob Rod
Drivers door
rear door quad cab
Passenger Front door
J
jordang
Canada
Why not install new knobs like in the below photo
True 5th Gen. the little grooves at the top of are flush with the top of the door so someone could pry it up I suppose
J
jordang
Canada
This is what I’m talking about. Trying to avoid being a theft victim. Now that I see those videos, a thief could just pull the handle rather than touching the knob. Seems like there’s no winning
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
If they want it they will get it!
Just wondering what are you going to do about the door glass if they cant get the knob they will just break the window !!!!
like i said before if they want in or want the truck they will get it !!!
Just saying !!!
Dan J
Indiana
I can tell you from personal experience that if someone wants in your truck they will get in your truck. In my case they broke the rear door glass and opened the door using the door handle...since the door handle was used from the inside the alarm does not trigger, the window breaking will NOT trigger the alarm. They wanted the center stack 12" screen which they got. They knew exactly what they were doing since they did not damage any of the wiring harnesses attached to the back of the screen.
I was told a long time ago...locks only keep honest people honest, if a thief wants your stuff they'll get it
PolarisCobra
Mendon, MA
SST SO
To answer your question, I cut a 1/2 inch off the top of the lock button in my 4th gen truck. I sits just about flush with the door trim when it is locked. I only did it on the passenger side, my wife got the back of her arm pinched several times when it auto locks at 15(?) mph.
It seemed easier than cutting her arm off, which seemed like the only other option :superhack:.
mikeru
Super Moderator
2020 Limited
I have heard this all my life, and couldn't disagree more. There's no need for locks for honest people because honest people wouldn't by trying to get into someone else's truck, house, property, etc.
Bj Binette
Canada
I unscrewed mine on the driver's side a year ago because I was tired of getting pinched when it auto locked lol works fine
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
Does the power lock button stay active when truck is off? Someone could also just use a hanger to push the button?
Dusty
Rochester, New York
Actually, on my '19 DT the front door lock knobs recess into the door and are flush. The rear doors, however, stick up far enough that one could easily pull the knob upwards and unlock the door.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build Date: 3 June 2018. Now at 88148 miles.
Dusty
Rochester, New York
I assume you didn't tell her that cutting off her arm was option #2!:D
Regards,
Dusty
