Double din upgrade
homebrew
Cummins
I have a 14 express with the factory 5.0 uconnect radio. I have a pioneer dvd/CD player that I would like to replace it with. My question, is it possible to maintain the factory hands free if I add the pioneer?
1500ram12
5.9L Cummins
No. You'll have to use the pioneers Bluetooth.
Sent from my D6708 using Tapatalk
Cyborg2337
South Jersey
Correct, you will have to use the Pioneer Bluetooth. I just replaced mine with the AVH-X3600BHS. I ran my Bluetooth microphone up the pillar and across to the mirror. It works great but I had to cut the bottom off of the metal bracket to fit the double din.
NJ4X4
South Jersey
Cyborg2337 - did you install a back-up camera when you put your system in? I just installed a Pioneer head unit and back-up camera. The only thing left to do is tie one wire into the reverse trigger. Do you know what wire that is?
1500ram12
5.9L Cummins
Check the manual for the radio i believe it will tell you their if not the wiring diagram for the harness you used should
NJ4X4
South Jersey
I'll double check the manual... The instructions with the camera wire said to tie-into a pink/green wire on a main harness behind kinda behind the emergency brake. I tried that and it didn't work. I found other things online about tieing into a white/blue wire there. I'll also check my harness instructions.....but, I didn't think I was tieing into that.
1500ram12
5.9L Cummins
On the pioneer manual (i just chose the 4600) it says to tie into the violet/white wire from the headunit. The pink/green wire is the parking break wire. That lets the headunit know that the parking brake is on so you can view dvds
NJ4X4
South Jersey
Thanks! I've got an AVIC-5000NEX.... I'll check that manual.
1500ram12
5.9L Cummins
Should be around page 52
NYCruiser
Yonkers, NY
What do you do about the truck features that are controllable from the 5.0 screen after you change it out?
1500ram12
5.9L Cummins
You won't be able to change them. So anything controlled through the radio make sure you have them set at what you want.
Cyborg2337
South Jersey
Sorry, I did not install a back up camera. I know there is an input specifically for it and the wiring should be pretty simple. Not sure on the colors though. The wiring harness instructions should have it. I bought mine from Crutchfield who is awesome and their customer service is great. I also would recommend a bypass for the DVD/parking break. I got one from Amazon and it works flawlessly. Hookup for that was easy, directions came with it.
Cyborg2337
South Jersey
The truck features are lost once an aftermarket is installed. You can get adapters that can be used for some things like steering wheel controls, Nav, back up camera, etc. I believe those are bought from Pioneer and wired in. My Pioneer HU came with Bluetooth and a USB cable, which is really all I wanted. But I can get the other plugins from Pioneer.
homebrew
homebrew
Cummins
What's to be lost removing the 5.0? Other than the steering wheel controls. I'd like a back up camera, don't really have any complaints about the stock stereo. Would it just be easier to get a factory back up camera installed?
jbr
Long Island, NY
All uConnect functions. You have to set them before you remove headunit.
