Dreaded No Bus.
DoubleaughtDodge
Kingston Ontario
5.2 magnum
Hey guys. New to the thread. 2000 Ram 1500, 5.2 magnum, and I got the dreaded no bus. Truck runs and drives ok, no gauges. Replaced the ECM as it fixed my old truck but didn't fix this one. I Ran the gauge diagnostics and everything checked out there. Also no DTC's when scanned.
Whats next to look for. Thanks!
pajeepman
SE PA
5.9 magnum
I would post this in 2nd gen section, not 3rd gen section.
Sent from my SM-A205U using Tapatalk
SportRam00
Joppa, MD
Magnum 360
If the truck still runs with the NOBUS message in the odometer, then the PCM is most likely not the problem. I would start by checking the wiring and plugs for the cluster all the way back to the PCM and CTM.
Arturo Rojas
