carid
Raise your Dodge Ram above the masses and customize its looks and performance with the new Softride Coil Spring Front and Rear Suspension Lift Kit by Skyjacker. This kit allows you to receive a 4-inch lift, increase your rig's ground clearance, maintain the high level of the original ride quality while also providing key features needed for off-road durability. If the original ride quality, long-lasting comfort, and aggressive look are your main goals, this kit is for you.
Along with its front and rear ride balanced design, you get an unmatched performance. Each kit comes with all the components you'll need, including front and rear coil springs, front track bar brackets, front polyurethane bump stops, sway bar brackets, radius arm brackets, and more.
Cross the roughest terrains with confidence after installing the new Softride Lift Kit by Skyjacker.
Skyjacker® - 4" Softride™ Coil Spring Front and Rear Suspension Lift Kit
Specifications:
Includes:
Specifications:
- With Front Coil Springs
- With Rear Coil Springs
- With Front and Rear M95 Monotube Shocks
- Max Tire Size: 37"x12.5"
- Wheels and tires recommended parameters: 37"x12.5" with 5.625" Backspacing - trimming may be required
Includes:
- Front Coil Springs
- Front Track Bar Bracket
- Front Polyurethane Bump Stops
- Front Sway Bar Brackets
- Radius Arm Brackets
- Rear Coil Springs
- Rear Bump Stop Brackets
- Rear Sway Bar End Links
- Front and Rear M95 Monotube Shocks
