drive shafts
Lee A Genz
iowa
I have a 06 1500 laramie 4x4. can I drive it without the front drive axles?
moezer
Calgary
If u remove the axle shaft ur gonna leak oil from the diff and if the diff dries or is very lock on oil ur gonna have alot of metal on metal and destroy it... why's the reason to remove them?
Or do u mean ur front drive shaft
Sent from my SM-N950W using Tapatalk
HemiLonestar
Navy Badge Coast Guard
MD
Driveshaft (longitudinal) yes, axles (transverse) no
Tumbleweed
Does the '06 have a solid front axle or IFS?
If solid, then you can remove the axle shafts, but you will need to plug the ends of the axle housing tubes so the diff oil doesn't leak out.
If IFS, then NO.
L
Lee A Genz
iowa
the right and left axles do not go into differential, spline comes out and axle goes over them. I'm worried about where it goes into wheel hub. hub is bolted to a arm bracket.
Timkll
