Driver heated seat issue
lukas
New York
After I turn it on, it stays on for about 2 seconds then I hear a click and the heat switches off.
Any suggestions on where to start troubleshooting?
Thanks.
2010 Ram 1500 Larmie
Tach_tech
5.7L HEMI
You’ll need a scan tool that can retrieve the codes from the heated seat module. Most likely cause is a heating element is open.
L
lukas
New York
Let me know if you manage to find the fix.
harryh
canada
Like i said in the other thread my 2011 larmie longhorn does the same thing.. I just shut the truck off and restart it and it works every time..
I usually have to do that two out of ten times i start the truck the drivers seat shuts off so I just restart the truck
Victor Brill
Kansas City
Bumping to see if anyone has found a common fix on this? Having the same issue in my 2011 Laramie. Have heard it could be a bad heating pad.
Tach_tech
5.7L HEMI
That is the common fix.
Firetruck41
Washington State
2500 Mega Cab Hemi 5.7
Mine does the same, the fix is to replace the pad. If you have cooled seats, the air channel pad is also part of it. I think it's around $200, IIRC. I might repair it this fall, though I just lived with it last year. It will require hog rings and hog ring pliers (maybe $15-20 for both). You can watch a YouTube video by The Seat Shop, if you want to see how to remove and reinstall the leather cover.
AkNoad2
Mine was doing the same thing, I bought a new seat cover from the Seat Shop, took the seat apart and checked the heating pad and it was fine, swapped out the cover and now my heater works again. Not sure what I did but my butt will be happy come winter.
