Rear heated seats
JimG96
Katy, TX
5.9 Cummins
I have a 2015 longhorn with rear heated seats. The passenger side doesn't work - when you push the button it lights up for a few seconds and then turns off. Driver side is fine.
The plug between the back and bottom has 4 wires. Are 2 sensors and the other 2 power / ground?
I only get resistance between two wires (can't remember the colors). 22 ohms on the passenger side, 13 on driver side. Is 22 ohms out of range and a bad element?
Thanks for any ideas and help!
aimcgma
