Driver seat wiring seatbelt chime
Shawn PUTNEL
Weatherford Texas
6.7 cummins
Ok I have a 2011 bighorn I updated the seats to a 2018 laramine seats throughout. Everything is working except the seatbelt chime thingy has anyone had this happen or know exactly what wires to hookup to get this to work properly?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Is it chiming or not chiming?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Its chiming like it would if the seatbelt is not on
You can try this manual process to turn off the chime completely. I did it in my father in law's 2012.
https://itstillruns.com/disable-belt-alarm-dodge-ram-7379517.html
Step 1
Sit in the driver's seat and shut all the doors.
Step 2
Put the key into the ignition and fasten your safety belt. Turn the vehicle to the "on" position, but don't start the engine. Wait for the safety belt light to turn off on the instrument panel.
Step 3
Fasten and unfasten your safety belt three times within one minute of turning the vehicle to the "on" position. Then fasten the seat belt one last time.
Turn the key to the "lock" position. You should hear the bell chime one time. This is an indication that the Ram's BeltAlert system has been turned off
As far far fixing the wiring, I'm not sure but @Mpgrimm2 may know and/or can sell you a harness to correct the issue.
Shawn PUTNEL
Shawn PUTNEL
Weatherford Texas
6.7 cummins
But it's not hooked up to be able to do this at all!
I posted a pic of the plug I just need to know what wires are to the seatb6
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
If it's not hooked up that's likely the problem. It might fail in the alarmed state (unless I'm misunderstanding your situation)...
Shawn PUTNEL
Shawn PUTNEL
Weatherford Texas
6.7 cummins
I really just dont know what wires on the plug I posted a pic of are for the seatbelt I've got everything else working right just not the seatbelt
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Yes it's a seat from a 2018 laramine my truck is a 2011 the plugs are not the same
Ok I got it now.
One caveat, the seats have airbags in them so be careful.
That said, this site might help you match things up. It's has pinouts for factory connectors.
http://connectors.dcctools.com/home.htm
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Where can I find what you're talking about?
Use the filters to select the year and type of vehicle (2011 1500 should be "DS"). On the next screen try using the search filter to narrow down the results. Type in "seat" and you will get pinouts for seat related harnesses.
gypsy400
Bright yellow plug tells me that is an airbag plug.. I bet your 2011 doesn't have side air bags?
Sent from my SM-G960W using Tapatalk
Jimmy07
Pins 11&12 are the seatbelt wires.
Marty424
