Drivers seat help....
odinjunior
Az
2021 Tradesman 3500 seat only manually reclines. Sure do miss the 6 Way power seat in my Big Horn.
What can I get to make this seat more comfortable? Got some cushions from Amazon but not much help.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You can swap it for an OEM power seat. Just need to run power to it.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
You can buy used bases
They make 6 way seats, it comes with 3 motors
If i recall correctly, the motors are interchangeable, but it takes a bit of fussing around
There is a good possibility that you will find the wiring under the rubber floor mat
joshhhh
