luvmyhemi
Replacing factory projectors in my 2015 Longhorn with new VLAND LED projectors. The kit came with a wire for DRL that runs to the fuse box. My question is 'Is this wire needed for DRL if I change the configuration values listed below in Alfa OBD?
These are the settings I've compiled in reading the 700+ threads...
DRL Configuration: Optional DRL
DRL Lamp Location: Dedicated
DRL Dropout Enabled: Yes
LED Dedicated DRL present: Yes
LED Low Beam Lamps present: Yes
LED High Beam Lamps present: Yes
LED Front Park/Marker Lamps present: Yes
CBC I/O Left Dedicated DRL Lamp Output present: Yes
ECU Config 3 DRL Customer Setting Enable: Yes
Cust Set Menu 1 Daytime Running Lights CSM: Yes
Is there anything listed that should or should not be changed? Thanks for your
