Dumb ac control question
EWC88
Southern NJ
Ok this is dumb but hey I don't care lol. I was always confused on why my truck doesn't have a recirculate option on my controls. When looking online to figure why this is I have seen everywhere of people saying it does and also showing controls with the option all the way to the left bottom. Well my left bottom next to the two option of either top vents or both top and bottom, instead of the recirculate sign it just says MAX.
So do I have recirculate or not? lol
usaf2006
North Carolina
I don't know if you do or not, but if you did, the door probably would have broke like 103% of all 3rd gens, so then you wouldn't have it anyways unless if you paid to fix it. So I guess that means you won since you neither had to deal with it nor pay to fix it?
Lol...
txcobowhunter
Cabool, MO.
2016 SSV
Yes you do. When you set the AC to max, it automatically goes to recirculate.
E
EWC88
Southern NJ
Ok cool. Now would I be able to hear the door open to know if it's working? I know when I got my heater core done I also purchased a blend door to replace the other just because I heard that was common to break. Is that the door?
justin13703
MD
Blend door is the one that controls temp.
To see if the recirc door is working, set the controls to a mode other than max Ac, and turn the blower on as high as it will go. Crack the driver side window about an inch and you should feel air rushing out of it from the outside of the truck. Now do the same thing with it on max Ac. There should be little to no air blowing out of the window.
Or just listen to it. It should get noticeably louder when you set it to max Ac. If you can't hear a difference, then try the method above.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Lol...
Hey! Mine is working just fine... my mode 2 door is the only one that broke.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
The air will blow harder when it recirculates.
Raadz
