Nice!
Most dyno operators use 1:1 because it removes the tranny gearing from the calculations. Usually not a huge difference doing pulls in a lower gear, but will usually show higher numbers. However weather variations can have a big affect regardless of ratio. As can heat soak. Hell, the numbers will usually change from pull to pull due to the later. Dynos are cool for two things. (1) Bragging rights. (2) Tuning and comparing component swaps. But neither directly translates to track times. The dyno is an artificial environment. But it's still cool to have some numbers. Most operators also use SAE correction so numbers are comparable to pulls done in different locations. Altitude, for example, makes a huge difference.
For those without a dyno handy, and/or that've been to the track. You can get a somewhat representative number from your weight and 1/4 mile trap speed. Many drag racers rely on this calculation alone, but it's ballpark. There are plenty of calculators for this on the web. Or you can use mine if you like.
http://www.mcvw.com/mcvw/calcs.php
wink
