soapy
All auto makers would like to go to a 48 volt system due to the weight savings of being able to run smaller wire. 48 volts is said to be the highest voltage they can go without causing damage to the human body.
Try this, see if it helps
LOL mileage calculations, I do not care the in least of the MPG gain, its that 130 torque off the line!
That torque is worthless if towing a heavy trailer up a long grade and if not towing then the extra torque is only a number with no relevance. Same problem with the Ford V6 engines with their turbo chargers. On a long grade when pulling a trailer the turbo overheats and then the engine does a complete shutdown.
How much will the motor/generator cost to replace,that's the question?
