Eagle Head Swap
Bigdaddycodes
Swift Current Saskatchewan
Hey guys, just curious as to who has all done the eagle head swap onto the early hemi. My friend has an 04 and we are looking at doing it to his. Basically im just trying to figure out what all im going to need and what possible issues I might face along the way.
My biggest issue I can forsee is the combustion chamber in the eagle head is smaller and therefore will increase compression, if my calculations are correct, itll be around a 12.1:1,
any help or tips would be greatly appreciated
charonblk07
Calgary, Ab
F1-A forged 349ci
I used a double thick Cometic gasket to drop the compression to a more reasonable 11:1. The intake and exhaust ports are different shapes but either a set of headers from an '09+ or trying to port match the existing headers is needed, you'll also want to change the intake manifold; it's not a must but the port mismatch is pretty bad. I've heard of some people using an adapter plate but that was typically used for the pre-Eagle heads to a 6.1L manifold but they flipped them so I don't know how well they aligned. I dropped a 6.1L manifold onto mine so I just needed the accessory spreader bracket.
