EBS/ABS lights coming on intermittently?
EClare
diesel
I had new front brake pads and rotors done by small local shop. Total cost was just over $400. Rotors had small heat cracks. ABS & traction ights have not come back on yet, we'll see. Thanks for the help!
Cuda Tom
Maryland USA
I also have a 2018 2500 with the ABS issue in need of a new HCU 68143491AB and the dealer told me they can't even order it until mid August. Are there any available anywhere?????
Dutra
bay area
I found the part but arrived damaged. Dealership will most likely not install it. Sending it back. This is a mess!
Cuda Tom
Maryland USA
Dutra, can you tell me where you found yours, and as it the "AB" model? Thanks!
Dutra
bay area
Yes, 68143491AB is the Hydraulic control until and 68347098AB is the control module which also can be bad. See the other posts for what my work order said. Most likely the same issue.
Clear Lake Dodge of Webster, TX had the parts
Fatboy1989
