ECM Issue
MoparGuy1973
Show Low, Arizona
My 2004 Ram 1500 keeps stalling out on me. I had my mechanic go thru it and he thinks it is the ECM bc the light on the dash is a lightning bolt inside 2 reverse parentheses. He hooked up his equipment and its not getting power to the ECM. Originally he thought it might be the throttle body. Ive been told that i have to take it to a Dodge dealership to have it diagnosed which is $125 then $125 if it needs to be reprogrammed. A new ECM is $325 through my local parts store, but I know that the dealership in town will not want to install it for me. They will want me to purchase their ECM which will cost me way more money than an OEM replacement. Any ideas??
jws123
nj
Honestly its almost never the pcm proably a wiring issue to the throttle body have you had it scanned? if so what are the codes?
MoparGuy1973
MoparGuy1973
Show Low, Arizona
My mechanic hooked up some scanner type of thing after he took the throttle body apart and checked it out, then he hooked up a scanner type of thing and he said there is no power going to the throttle body
jws123
nj
I would check for a wiring issue trace back the wires from throttle body you need a good wire diagram also the dealership is probably not the best place to take it find a good independent shop.
MoparGuy1973
MoparGuy1973
Show Low, Arizona
Im not a fan of taking my truck to my local dealership. They recently got bought out and the techs ive dealt with there seem to do their job half ass. Its like theyre just there for a paycheck and have no love for being a MOPAR mechanic
MoparGuy1973
MoparGuy1973
Show Low, Arizona
im no mechanic or electrician by any stretch of the imagination, so what would i be looking for when i trace the wiring back to the ecm
rockyj69
