ECM - Rush to Replace? Why?
KoboldTaco
Los Angeles
Cummins 6.7L
Hey guys -
Don’t throw a tomato at me if this is you. I notice a lot of threads when trying to diagnose a tricky issue, folks are quick to ask if an ECM replacement is required. I realize Chrysler is not known for electrical system stability, but I think an unusual amount of folks ask if they should replace the ECM. What I don't see is:
- any electrical system isolation/troubleshooting
- wiggle testing
- relay / fuse testing
- ground testing
- Code reading, system checking with a proper OBD II computer and diagnostic solution
I also just saw a thread where a battery had not been replaced in over 10 years and ECM replacement was mentioned. Again, I'm not trying to be critical but I am for sure curious if Chrysler had a bad run of computers for a number of years?
What are your thoughts? Do you notice the same thing? Are the ECMs all crap and a logical place to start? It feels not, but that's just me.
alpinegreenneon
Air Force
South East Wisconsin
The ECM is almost always the last possibility listed in the FSM for possible causes for just about any code. Too many so-called mechanics are just parts changers. Replacing a ECM is just a quick easy money maker and rarely fixes the problem. There are actual codes for a failed ECM. The only time I have ever seen a failure in one of my vehicles, there was a code for an internal failure but the truck ran just fine.
pacofortacos
In my experience, it is extremely rare for a Mopar ECM to fail - almost always something else has failed.
KoboldTaco
KoboldTaco
Los Angeles
Cummins 6.7L
That is a good point to reference the type of backyard mechanic that will just swap out the part vs. Understand why he/she is swapping it out. I believe the former director of flight operations at NASA was famous for saying ” let's not make the problem worse by guessing” when handling the Apollo 13 incident. None of that when swapping out the ECM eh? :D
