Eco mode
Bearcatrp
When my 6.4 goes into Eco mode (rarely) seems the engine isn't running on all cylinders. the manual doesn't cover anything on Eco mode. Feels weird too. Can someone enlighten me on this? thanks.
Boosted Motorsports
You are correct, that is exactly what is happening. It turns off a few cylinders to save fuel when it doesn't need them.
ramittome
Gonzales, LA
"Eco mode" as you call it is just the truck letting you know when it's getting the best gas mileage.
What you're feeling is when MESS kicks in. It kills power to half the cylinders, therefore you hear a sound change because it's literally not firing on all cylinders (yes, that was a pun), and is then getting the best gas mileage.
Depending on the type of shifter you have, you can turn it off by putting it into 8th gear, or with a programmer to turn it off completely.
MADDOG
Living in a Firepit
6.4L HEMI
Yup...ECO mode will bring about MDS, Multi-Displacement System. It "deactivates" 4 cylinders when on.
Thorvald
Ontario, Canada
Has anyone found a way to force ECO mode on? Wife drives barely 3km to work everyday, I'd love to force it into 4 cylinder mode until needed to get the fuel economy. Don't need 400 horse to go through 2 stop signs up two streets lol.
I know, sound ludicrous since most people want to kill MSD but I love it for saving $$$$.
huntergreen
Marine Corps Navy Badge
No way I am aware of.
B
Bearcatrp
I have a 6 speed tranny. Sounds and feels weird when it kicks in. But it rarely kicks in. Love the towing power but miss my 2014 8 speed gas mileage. Thanks folks.
Wahrsuul
Central S.C.
Yup, wish there was a way to get MDS on more often. Why it doesn't idle in MDS.... if they can build cars that shut off at stoplights/idle.
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
May be an issue with having the Hemi idle at such a low RPM on four cylinders without causing excess vibration.
Rampant
NJ
392 Hemi
You wouldn't want to do that because then you'd be lugging the motor while trying to move a 6k lb truck with 4 cylinders, rather than kind of "coasting" or very low-load condition only as it does when MDS kicks in.
EDIT: Sorry, I thought you had a 1500... so prob closer to a 7k-ish lb truck
Rampant
NJ
392 Hemi
Here's an overview of the system out of the book for you:
DESCRIPTION
The Multi Displacement System (MDS) selectively deactivates cylinders 1, 4, 6, and 7, to improve fuel economy. It has two modes of operation:
- 8 cylinders for acceleration and heavy loads.
- 4 cylinders for cruising and city traffic.
The main components of the Multi Displacement System are:
- Unique MDS camshaft.
- Deactivating roller tappets.
- 4 control valves/solenoids.
- control valve/solenoid wiring harness.
Trooper2
I actually have better gas miliage turning it off. I know it sounds unlikley but its true. I have run without and with it and i consistently get better gas miliage when i turn it off most of the time.
Reactions: CTD
zogg
Southern Illinois
2018 Ram Express Quad Cab
I installed a performance muffler and eco mode sounds crummy. Wish I could turn it off
KansasArt
Kansas
I too dislike it. Have 5.7/8 speed. Seems like when it engages and you want to just maintain speed it bogs down like too little rpm or too high of gear. Been turning it off via the gear select. 5 for city & 7 for highway. Of course 8 for extended highway.
Trooper2
Also im not sure turning the cylinders on and off can be good either.
Wahrsuul
Central S.C.
FCA tested it over lots of miles/cycles and didn't see any appreciable difference in wear. They've been using it on the 5.7 cars for years (Magnum, 300, Charger) with no particular issues.
Trooper2
I kinda feel like i do not see much benefit from it though.
Lowwhiteram02
How do you disable the mds? Dont want to use a tuner sisnce i still have a warranty
CTD
Southwest, VA
Same hear. I have had mine cut off for 8 months via a custom tune and my gas mileage is about the same if not a little better then when I was running with MDS.
joshhhh
